Ir para o conteúdo principal
LG Spectrum Sim/SD Port Replacement
O que você precisa
  1. LG Spectrum Sim/SD Port Replacement, Battery: passo 1, imagem 1 %32 LG Spectrum Sim/SD Port Replacement, Battery: passo 1, imagem 2 %32
    • Using your thumbnail, lift up on the notch in the middle of the bottom side of the phone.
  2. LG Spectrum Sim/SD Port Replacement: passo 2, imagem 1 %32
    • Using either your thumbnail or a plastic opening tool, lift up on the battery using the notch in the bottom left hand corner of the battery and remove it from the phone.
  3. LG Spectrum Sim/SD Port Replacement, Sim/SD Port: passo 3, imagem 1 %32 LG Spectrum Sim/SD Port Replacement, Sim/SD Port: passo 3, imagem 2 %32
    • Remove eleven 4mm Phillips #000 screws with a PH000 screwdriver.
    • Use the magnetic mat to keep the screws in one place.
  4. LG Spectrum Sim/SD Port Replacement: passo 4, imagem 1 %32
    • Use the plastic opening tool to firmly pry up the plastic backing around the perimeter of the phone.
  5. LG Spectrum Sim/SD Port Replacement: passo 5, imagem 1 %32
    • Detach the black rectangular film attached to the SIM/SD card plate with a plastic opening tool.
  6. LG Spectrum Sim/SD Port Replacement: passo 6, imagem 1 %32
    • Hook the plastic opening tool underneath the plate and gently lift it up.
  7. LG Spectrum Sim/SD Port Replacement: passo 7, imagem 1 %32
    • Gently wiggle the plate side-to-side while pulling up to release it from the metal clamps holding it in.
Conclusão
Aiman Sallam
Membro desde: 02/10/16
506 Reputação
Autoria de 5 guias
Equipe
USF Tampa, Team 1-4, Sullivan Spring 2016 Membro de USF Tampa, Team 1-4, Sullivan Spring 2016
USFT-SULLIVAN-S16S1G4
3 Membros
Autoria de 10 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 5
Últimos 30 dias: 29
Ao todo: 387
