Ir para o conteúdo principal
LG Risio Motherboard Replacement
O que você precisa
  1. LG Risio Motherboard Replacement, Back Panel: passo 1, imagem 1 %32 LG Risio Motherboard Replacement, Back Panel: passo 1, imagem 2 %32
    • Use a plastic opening tool to seperate the back panel from the device.
    • Remove the back panel.
  2. LG Risio Motherboard Replacement, Battery: passo 2, imagem 1 %32
    • Place your thumb along the bottom of the battery and pry upwards to remove.
  3. LG Risio Motherboard Replacement, Midframe: passo 3, imagem 1 %32
    • Press down on the SIM eject tab with a fingernail (or iFixit opening tool), and slide the SIM card out.
  4. LG Risio Motherboard Replacement: passo 4, imagem 1 %32 LG Risio Motherboard Replacement: passo 4, imagem 2 %32
    • Remove the eight Phillips #0 screws from the internal support frame.
  5. LG Risio Motherboard Replacement: passo 5, imagem 1 %32 LG Risio Motherboard Replacement: passo 5, imagem 2 %32 LG Risio Motherboard Replacement: passo 5, imagem 3 %32
    • Use an opening tool on the marked locations to lift the edges up. There should be a small click when lifting these edges up.
  6. LG Risio Motherboard Replacement: passo 6, imagem 1 %32
    • Using your hand, pick up the midframe to separate it from the phone.
  7. LG Risio Motherboard Replacement, Motherboard: passo 7, imagem 1 %32 LG Risio Motherboard Replacement, Motherboard: passo 7, imagem 2 %32
    • Detach the screen connector from the motherboard by putting your thumb underneath it and lifting up.
    • The screen connector is the part that has P5 written on it.
  8. LG Risio Motherboard Replacement: passo 8, imagem 1 %32
    • On the side with the screen connector, pull the two tabs away from the device.
    • Use the plastic opening tool to lift the motherboard starting on the bottom right corner and pulling upwards.
Conclusão
Uma outra pessoa concluiu este guia.
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 1
Duração total: 250
