Pular para o conteúdo principal
Introdução
If your LG Risio front-facing camera is not functioning, use this guide to replace it.
Peças
Nenhum componente especificado.
  1. Use a plastic opening tool to seperate the back panel from the device. Remove the back panel.
    • Use a plastic opening tool to seperate the back panel from the device.
    • Remove the back panel.
  2. Place your thumb along the bottom of the battery and pry upwards to remove.
    • Place your thumb along the bottom of the battery and pry upwards to remove.
  3. Press down on the SIM eject tab with a fingernail (or iFixit opening tool), and slide the SIM card out.
    • Press down on the SIM eject tab with a fingernail (or iFixit opening tool), and slide the SIM card out.
  4. kits de reparo de baterias de iPhone
    Only $29.99
    Buy Now
    Only $29.99
    Buy Now
  5. Remove the eight Phillips #0 screws from the internal support frame. Remove the eight Phillips #0 screws from the internal support frame.
    • Remove the eight Phillips #0 screws from the internal support frame.
  6. Use an opening tool on the marked locations to lift the edges up. There should be a small click when lifting these edges up. Use an opening tool on the marked locations to lift the edges up. There should be a small click when lifting these edges up. Use an opening tool on the marked locations to lift the edges up. There should be a small click when lifting these edges up.
    • Use an opening tool on the marked locations to lift the edges up. There should be a small click when lifting these edges up.
  7. Using your hand, pick up the midframe to  separate it from the phone.
    • Using your hand, pick up the midframe to separate it from the phone.
    • If the midframe does not want to lift off, go back and repeat step 6.
  8. Unclip the front camera connector from the motherboard and lift it from the frame. Unclip the front camera connector from the motherboard and lift it from the frame.
    • Unclip the front camera connector from the motherboard and lift it from the frame.
Conclusão
Amina
Membro desde: 21-02-2018
73 reputação
Autoria de 1 guia
Adicionar comentário
Visualizar Estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 6
Todo: 77
