Introdução
This is a guide to replace a broken or damaged front camera on the LG Rebel. this could apply to having a cracked screen or shattered front camera. Following these steps will help you in replacing your front camera.
O que você precisa
Turn phone over to its front side.
Use a spudger to begin removing the screen by the right hand corner. Begin to move the tool around the edges of the screen.
Once you have loosened the grip around the edges, pop off the screen using a suction cup.
Once the front screen is removed, place the phone on its side and find the groove located on the side.
Use the plastic opening tool to pop open the black plastic covering.
Remove black plastic cover.
Uma outra pessoa concluiu este guia.
