Introdução
This is a guide to replace a broken or damaged front camera on the LG Rebel. this could apply to having a cracked screen or shattered front camera. Following these steps will help you in replacing your front camera.
Peças
Não são necessárias peças.
  1. Turn phone over to its front side. Use a spudger to begin removing the screen by the right hand corner. Begin to move the tool around the edges of the screen. Use a spudger to begin removing the screen by the right hand corner. Begin to move the tool around the edges of the screen.
    • Turn phone over to its front side.
    • Use a spudger to begin removing the screen by the right hand corner. Begin to move the tool around the edges of the screen.
  2. Once you have loosened the grip around the edges, pop off the screen using a suction cup. Once the front screen is removed, place the phone on its side and find the groove located on the side. Use the plastic opening tool to pop open the black plastic covering.
    • Once you have loosened the grip around the edges, pop off the screen using a suction cup.
    • Once the front screen is removed, place the phone on its side and find the groove located on the side.
    • Use the plastic opening tool to pop open the black plastic covering.
    • Remove black plastic cover.
  3. Free shipping on all orders over US$100,00 or containing a Pro Tech Toolkit!
    Visite Nossa Loja
  4. Locate the small groove on the back of the phone near the bottom. Use the metal spudger to pop open the black plastic covering. Remove black plastic covering.
    • Locate the small groove on the back of the phone near the bottom.
    • Use the metal spudger to pop open the black plastic covering.
    • Remove black plastic covering.
  5. Use the metal spudger to pop up the black plastic covering near top of phone. Remove the black plastic covering.
    • Use the metal spudger to pop up the black plastic covering near top of phone.
    • Remove the black plastic covering.
  6. Remove the motherboard with a spudger. Slowly begin to lift motherboard with your hand carefully. Once the motherboard is completely off, set the phone to the side and focus on the small black box with a square tail (which is the front camera).
    • Remove the motherboard with a spudger.
    • Slowly begin to lift motherboard with your hand carefully.
    • Once the motherboard is completely off, set the phone to the side and focus on the small black box with a square tail (which is the front camera).
  7. Remove the front camera by its tail with a spudger. Remove the front camera by its tail with a spudger.
    • Remove the front camera by its tail with a spudger.
Conclusão
Lesley Sigaran
133 reputação
Autoria de 1 guia
Visualizar Estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 12
Todo: 72
