Introdução
This guide is made to help remove the battery from your phone if you are having problems with it or need to replace it. The only real hazard involving this step is removing the back plating of your phone.
O que você precisa
Slide a plastic spudger, or guitar pick, between the back and front panel at the bottom .
Uma outra pessoa concluiu este guia.
