Introdução
If you need to install a new outside trim on your LG Phoenix 2, use this guide to disassemble and replace the damaged outer trim. For this guide you will need a plastic opening tool and a Phillips #000 screwdriver head. These steps will be straightforward and easy to follow, but the pieces should be handled with care, so as to not damage or misplace any needed components.
O que você precisa
Insert a fingernail in the notch on the bottom right corner of the phone.
Pop off the back cover off of your device.
