Ir para o conteúdo principal
LG Phoenix 2 Motherboard Replacement
O que você precisa
  1. LG Phoenix 2 Motherboard Replacement, Battery: passo 1, imagem 1 %32 LG Phoenix 2 Motherboard Replacement, Battery: passo 1, imagem 2 %32 LG Phoenix 2 Motherboard Replacement, Battery: passo 1, imagem 3 %32
    • Place a fingernail in the notch at the bottom edge of the phone.
    • Pull on the back cover with one hand while keeping the rest of the phone steady, and run your fingernail along the edge.
  2. LG Phoenix 2 Motherboard Replacement: passo 2, imagem 1 %32 LG Phoenix 2 Motherboard Replacement: passo 2, imagem 2 %32 LG Phoenix 2 Motherboard Replacement: passo 2, imagem 3 %32
    • Place a fingernail in the notch at the bottom edge of the battery.
    • Pull the battery out.
  3. LG Phoenix 2 Motherboard Replacement, Motherboard: passo 3, imagem 1 %32 LG Phoenix 2 Motherboard Replacement, Motherboard: passo 3, imagem 2 %32
    • Remove all nine of the 3.0mm screws on the back of the phone using a Phillips #0 screwdriver, including the one attaching the camera lens.
  4. LG Phoenix 2 Motherboard Replacement: passo 4, imagem 1 %32 LG Phoenix 2 Motherboard Replacement: passo 4, imagem 2 %32
    • With the plastic opening tool, pry between the screen and the outer chrome edge to remove the bottom shield from the rest of the phone.
  5. LG Phoenix 2 Motherboard Replacement: passo 5, imagem 1 %32 LG Phoenix 2 Motherboard Replacement: passo 5, imagem 2 %32 LG Phoenix 2 Motherboard Replacement: passo 5, imagem 3 %32
    • With a plastic opening tool, disconnect all three ribbon connectors from the motherboard: one for the front camera, one for the rear camera, and one for the screen.
  6. LG Phoenix 2 Motherboard Replacement: passo 6, imagem 1 %32 LG Phoenix 2 Motherboard Replacement: passo 6, imagem 2 %32 LG Phoenix 2 Motherboard Replacement: passo 6, imagem 3 %32
    • Using a plastic opening tool, separate the motherboard from the back frame and remove it from the device.
Conclusão
5 outras pessoas executaram este guia.
Alex Selsley
Membro desde: 11/04/19
325 Reputação
Autoria de 2 guias
Equipe
IUPUI, Team S1-G1, Harley Fall 2019 Membro de IUPUI, Team S1-G1, Harley Fall 2019
IUPUI-HARLEY-F19S1G1
Membros da 3
Autoria de 4 guias
Um comentário
Are the LG Phoenix 2 and LG K8 motherboards interchangeable?
Jon Doer - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 3
Últimos 30 dias: 4
Duração total: 530
