Introdução
This guide will walk you through the process of replacing a camera in an LG Phoenix 2. This guide should be used if the phone does not take photos. This guide should also be used if the camera only takes blurry photos reguardless of the position of the camera or the object that is being photographed.
O que você precisa
Place a fingernail in the notch at the bottom edge of the phone.
Pull on the back cover with one hand while keeping the rest of the phone steady, and run your fingernail along the edge.
Locate the SIM card in the top right corner on the back of the phone.
Remove the SIM card by pushing it with your thumb from left to right.
