Introdução
The motherboard of the LG Optimus Zone 3 is a circuit board that is the backbone of the phone. It is responsible for connecting various parts of the phone and allows for communication between these parts so your device can function properly.
O que você precisa
Insert fingernail into the slot on the back left side of the phone and pry open.
Remove faulty battery.
This guide isn’t very clear by what they mean when they say “screen” which is actually the digitizer.
This guide also fails to mention that you will need to apply heat (perhaps a lot) to soften the adhesive holding the digitizer to the LCD and the phone.
If your needing to replace the LCD you’ll need a new digitizer as well because…
I have yet to see this disassembly performed in a video online without incurring damage to the digitizer. All the videos show removal of the digitizer (cracking and splintering as they go), then the LCD. Also it looks like its not possible to remove them together due to the amount of adhesive LG uses under the digitizer at the top and bottom of the phone. It is unlikely that the digitizer would remain undamaged during the removal process regardless. Maybe if the adhesive is heated enough without melting the phone’s plastic frame it may come willingly but don’t count on it.
Insert the plastic opening tool into the groove between the screen and the rest of the device. Work your way around the perimeter by sliding the opening tool around the edge, loosening the screen.
Insert plastic opening tool into groove between display and body of the phone. Work your way around the edges to loosen the display, and finally remove it with your fingers.
Um comentário
I have yet to see this disassembly performed in a video online without incurring damage to the digitizer. All the videos show removal of the digitizer (cracking and splintering as they go), then the LCD. It looks like its not possible to remove them together due to the amount of adhesive LG uses under the digitizer at the top and bottom of the phone. It is unlikely that the digitizer would remain undamaged during the removal process regardless. Maybe if the adhesive is heated enough without melting the frame it may come willingly.
Anyone care to demonstrate otherwise?
So with that in mind it looks like I’ll need to order another digitizer before I pull a good LCD and (soon to be broken) good digitizer from a donor phone to replace the broken pair in my phone.
Just sayin’
