Ir para o conteúdo principal
LG Optimus Zone 3 Micro SD Card Replacement
O que você precisa
  1. LG Optimus Zone 3 Micro SD Card Replacement, Battery: passo 1, imagem 1 %32
    • Insert fingernail into the slot on the back left side of the phone and pry open.
  2. LG Optimus Zone 3 Micro SD Card Replacement: passo 2, imagem 1 %32
    • Remove faulty battery.
    • The battery is missing from our device, however, it would be located in the section in-between the fingers.
  3. LG Optimus Zone 3 Micro SD Card Replacement, Micro SD Card: passo 3, imagem 1 %32
    • Locate Micro SD Card Slot.
    • In our device shown, there is not currently a micro SD card in the device. However, it would be located in the slot where the finger is pointing.
  4. LG Optimus Zone 3 Micro SD Card Replacement: passo 4, imagem 1 %32
    • Using Tweezers grab onto the Micro SD Card and remove.
Conclusão
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 0
Duração total: 356
