Ir para o conteúdo principal
LG Optimus V Speaker Replacement
O que você precisa
  1. LG Optimus V Speaker Replacement, Battery: passo 1, imagem 1 %32
    • Turn the LG Optimus V over, so that the back cover is facing upward.
  2. LG Optimus V Speaker Replacement: passo 2, imagem 1 %32
    • Locate the opening above the camera.
    • Use a spudger to detach the back cover.
  3. LG Optimus V Speaker Replacement: passo 3, imagem 1 %32 LG Optimus V Speaker Replacement: passo 3, imagem 2 %32 LG Optimus V Speaker Replacement: passo 3, imagem 3 %32
    • Gently remove the battery with your spudger.
  4. LG Optimus V Speaker Replacement, Camera: passo 4, imagem 1 %32 LG Optimus V Speaker Replacement, Camera: passo 4, imagem 2 %32
    • Remove the six screws on the silver casing.
    • Use the plastic opening tool to remove the silver casing.
  5. LG Optimus V Speaker Replacement: passo 5, imagem 1 %32 LG Optimus V Speaker Replacement: passo 5, imagem 2 %32 LG Optimus V Speaker Replacement: passo 5, imagem 3 %32
    • Use a plastic opening tool to remove each area holding the parts together.
  6. LG Optimus V Speaker Replacement: passo 6, imagem 1 %32 LG Optimus V Speaker Replacement: passo 6, imagem 2 %32
    • Use a plastic opening tool to remove the small black and yellow piece that reads Y3114C.
    • Use a plastic opening tool to pry off the camera.
  7. LG Optimus V Speaker Replacement, Speaker: passo 7, imagem 1 %32
    • This is the area that holds the speaker.
  8. LG Optimus V Speaker Replacement: passo 8, imagem 1 %32 LG Optimus V Speaker Replacement: passo 8, imagem 2 %32
    • To fix the speaker, use a soldering iron to heat up the two areas where the wires connect to the motherboard. Then, remove the old speaker and replace it with a new one by soldering it back onto the same areas.
    • Once you’re done, your speaker should be working properly again.
Conclusão
Uma outra pessoa concluiu este guia.
Equipe
UMass Dartmouth, Team 1-2, Shastany Fall 2013 Membro de UMass Dartmouth, Team 1-2, Shastany Fall 2013
UMASSD-SHASTANY-F13S1G2
Membros da 3
Autoria de 5 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 1
Últimos 30 dias: 1
Duração total: 778
