Introdução
This guide will walk you through how to replace the screen on your LG Optimus V phone.
O que você precisa
Remove the six screws on the silver casing.
Use the plastic opening tool to remove the silver casing.
Once you have removed the antenna, unscrew the two screws located on the sides of the charging port.
3 outras pessoas executaram este guia.
