Ir para o conteúdo principal
LG Optimus V Screen Replacement
O que você precisa
  1. LG Optimus V Screen Replacement, Battery: passo 1, imagem 1 %32
    • Turn the LG Optimus V over, so that the back cover is facing upward.
  2. LG Optimus V Screen Replacement: passo 2, imagem 1 %32
    • Locate the opening above the camera.
    • Use a spudger to detach the back cover.
  3. LG Optimus V Screen Replacement: passo 3, imagem 1 %32 LG Optimus V Screen Replacement: passo 3, imagem 2 %32 LG Optimus V Screen Replacement: passo 3, imagem 3 %32
    • Gently remove the battery with your spudger.
  4. LG Optimus V Screen Replacement, Camera: passo 4, imagem 1 %32 LG Optimus V Screen Replacement, Camera: passo 4, imagem 2 %32
    • Remove the six screws on the silver casing.
    • Use the plastic opening tool to remove the silver casing.
  5. LG Optimus V Screen Replacement: passo 5, imagem 1 %32 LG Optimus V Screen Replacement: passo 5, imagem 2 %32 LG Optimus V Screen Replacement: passo 5, imagem 3 %32
    • Use a plastic opening tool to remove each area holding the parts together.
  6. LG Optimus V Screen Replacement: passo 6, imagem 1 %32 LG Optimus V Screen Replacement: passo 6, imagem 2 %32
    • Use a plastic opening tool to remove the small black and yellow piece that reads Y3114C.
    • Use a plastic opening tool to pry off the camera.
  7. LG Optimus V Screen Replacement, Screen: passo 7, imagem 1 %32
    • Once you have removed the antenna, unscrew the two screws located on the sides of the charging port.
  8. LG Optimus V Screen Replacement: passo 8, imagem 1 %32 LG Optimus V Screen Replacement: passo 8, imagem 2 %32
    • Using your plastic opening tool, lift up the connectors on either side of the motherboard.
  9. LG Optimus V Screen Replacement: passo 9, imagem 1 %32
    • Remove the motherboard and set it aside.
  10. LG Optimus V Screen Replacement: passo 10, imagem 1 %32
    • Using a plastic opening tool, detach the screen from the plastic casing of the phone.
Conclusão
3 outras pessoas executaram este guia.
Equipe
UMass Dartmouth, Team 1-2, Shastany Fall 2013 Membro de UMass Dartmouth, Team 1-2, Shastany Fall 2013
UMASSD-SHASTANY-F13S1G2
Membros da 3
Autoria de 5 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 0
Duração total: 2,537
