Introdução
If your LG Optimus V is not getting service when it should, or is otherwise lacking full designed connectivity, use this guide to replace the antenna.
Keep in mind that Step 4 must be done very carefully in order to not damage the device.
Step 5 of this guide requires you to desolder the existing antenna and solder the new antenna in place on the circuit board.
Before beginning this repair, turn off your phone completely and disconnect from your charger.
O que você precisa
Remove the six screws on the silver casing.
Use the plastic opening tool to remove the silver casing.
Use a soldering iron to desolder the connections attaching the the antenna to the motherboard.
3 outras pessoas executaram este guia.
