Ir para o conteúdo principal
LG Optimus T Camera and Camera Mount Replacement
O que você precisa
  1. LG Optimus T Camera and Camera Mount Replacement, Camera: passo 1, imagem 1 %32 LG Optimus T Camera and Camera Mount Replacement, Camera: passo 1, imagem 2 %32
    • Working on your device while it is turned on may result in electric shock. Make sure to shut down your device before you begin.
    • Use a plastic opening tool to remove the phone's back cover. At the top of the phone there are indentations to insert the spudger and pop the case off
  2. LG Optimus T Camera and Camera Mount Replacement: passo 2, imagem 1 %32
    • Remove the battery by pulling up on the battery using the indentation to the left of the camera lens
  3. LG Optimus T Camera and Camera Mount Replacement: passo 3, imagem 1 %32
    • Use a J0 screwdriver to remove the 6 highlighted screws
  4. LG Optimus T Camera and Camera Mount Replacement: passo 4, imagem 1 %32 LG Optimus T Camera and Camera Mount Replacement: passo 4, imagem 2 %32
    • Remove interior case using indentations on the top and bottom to insert the spudger to pop off the interior case
    • You might have difficulty popping the interior case off. You may use the metal spudger here with caution if the plastic one fails
  5. LG Optimus T Camera and Camera Mount Replacement: passo 5, imagem 1 %32
    • Unhook the connector tab
  6. LG Optimus T Camera and Camera Mount Replacement: passo 6, imagem 1 %32
    • Remove SD card mount by inserting the plastic opening tool on the right side of the device to pop mount off
  7. LG Optimus T Camera and Camera Mount Replacement: passo 7, imagem 1 %32 LG Optimus T Camera and Camera Mount Replacement: passo 7, imagem 2 %32
    • Remove metal panel by inserting plastic opening tool into the four retaining points and remove panel
  8. LG Optimus T Camera and Camera Mount Replacement: passo 8, imagem 1 %32
    Ferramenta utilizada neste passo:
    • disconnect camera connector from motherboard by spudger
    • Once disconnected, remove camera using tweezers
Conclusão
stacey
Membro desde: 02/07/17
219 Reputação
Autoria de 2 guias
Equipe
Ohio State, Team 1-3, Wilder Spring 2017 Membro de Ohio State, Team 1-3, Wilder Spring 2017
OSU-WILDER-S17S1G3
Membros da 4
Autoria de 5 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 2
Duração total: 127
