Ir para o conteúdo principal
LG Optimus L9 P769 Rear Facing Camera Replacement
O que você precisa
  1. LG Optimus L9 P769 Rear Facing Camera Replacement, Removing the Back Panel: passo 1, imagem 1 %32 LG Optimus L9 P769 Rear Facing Camera Replacement, Removing the Back Panel: passo 1, imagem 2 %32
    • Pry the back panel from the frame of the phone to reveal the motherboard.
  2. LG Optimus L9 P769 Rear Facing Camera Replacement, Unpluging the Motherboard: passo 2, imagem 1 %32 LG Optimus L9 P769 Rear Facing Camera Replacement, Unpluging the Motherboard: passo 2, imagem 2 %32 LG Optimus L9 P769 Rear Facing Camera Replacement, Unpluging the Motherboard: passo 2, imagem 3 %32
    • Detach the connectors on the motherboard.
  3. LG Optimus L9 P769 Rear Facing Camera Replacement, Unpluging the Motherboard Cont.: passo 3, imagem 1 %32 LG Optimus L9 P769 Rear Facing Camera Replacement, Unpluging the Motherboard Cont.: passo 3, imagem 2 %32 LG Optimus L9 P769 Rear Facing Camera Replacement, Unpluging the Motherboard Cont.: passo 3, imagem 3 %32
    • Continue to lift the connectors off the motherboard.
  4. LG Optimus L9 P769 Rear Facing Camera Replacement, Lifting Motherboard from the Phone: passo 4, imagem 1 %32 LG Optimus L9 P769 Rear Facing Camera Replacement, Lifting Motherboard from the Phone: passo 4, imagem 2 %32 LG Optimus L9 P769 Rear Facing Camera Replacement, Lifting Motherboard from the Phone: passo 4, imagem 3 %32
    • Lift the speaker cable off the motherboard.
    • Lift the motherboard up. It will Still be connected to the frame.
  5. LG Optimus L9 P769 Rear Facing Camera Replacement, Pry and remove the camera: passo 5, imagem 1 %32 LG Optimus L9 P769 Rear Facing Camera Replacement, Pry and remove the camera: passo 5, imagem 2 %32 LG Optimus L9 P769 Rear Facing Camera Replacement, Pry and remove the camera: passo 5, imagem 3 %32
    • Pry under the camera to lift it off the frame.
    • There is some adhesive that will keep it attached to the frame, pulling the camera off will not damage the phone.
    • The camera should now be entirely separated from the phone.
Conclusão
Uma outra pessoa concluiu este guia.
Paul
Membro desde: 10/07/14
145 Reputação
Autoria de 4 guias
Equipe
USF Tampa, Team 8-1, Leahy Fall 2014 Membro de USF Tampa, Team 8-1, Leahy Fall 2014
USFT-LEAHY-F14S8G1
Membros da 4
Autoria de 5 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 1
Últimos 30 dias: 9
Duração total: 973
