Ir para o conteúdo principal
LG Optimus L9 P769 Micro-USB Port Replacement
O que você precisa
  1. LG Optimus L9 P769 Micro-USB Port Replacement, Micro-USB Port: passo 1, imagem 1 %32
    • Power off the device and gently lift the battery cover off to access the battery
  2. LG Optimus L9 P769 Micro-USB Port Replacement: passo 2, imagem 1 %32
    • Lift and remove the battery from the notch in the edge of the battery compartment
  3. LG Optimus L9 P769 Micro-USB Port Replacement: passo 3, imagem 1 %32 LG Optimus L9 P769 Micro-USB Port Replacement: passo 3, imagem 2 %32
    • Remove all 10 of the 4.5mm screws that hold the back frame to the case of the phone using a PH000 screwdriver.
  4. LG Optimus L9 P769 Micro-USB Port Replacement: passo 4, imagem 1 %32 LG Optimus L9 P769 Micro-USB Port Replacement: passo 4, imagem 2 %32
    • Using a small prying tool, carefully remove the back frame by prying on the sides of the device.
    • Do be careful when prying back frame and removing it as too much force may result in damaging the frame.
  5. LG Optimus L9 P769 Micro-USB Port Replacement: passo 5, imagem 1 %32 LG Optimus L9 P769 Micro-USB Port Replacement: passo 5, imagem 2 %32 LG Optimus L9 P769 Micro-USB Port Replacement: passo 5, imagem 3 %32
    Ferramenta utilizada nesse passo:
    Comprar
    • Remove both connections of the antenna by pulling up with tweezers
  6. LG Optimus L9 P769 Micro-USB Port Replacement: passo 6, imagem 1 %32 LG Optimus L9 P769 Micro-USB Port Replacement: passo 6, imagem 2 %32 LG Optimus L9 P769 Micro-USB Port Replacement: passo 6, imagem 3 %32
    • Remove Micro-USB Cache by unscrewing both 2.9mm screws with the PH000 headtype
  7. LG Optimus L9 P769 Micro-USB Port Replacement: passo 7, imagem 1 %32
    • Detach module from motherboard using a prying tool
  8. LG Optimus L9 P769 Micro-USB Port Replacement: passo 8, imagem 1 %32 LG Optimus L9 P769 Micro-USB Port Replacement: passo 8, imagem 2 %32
    • Remove 1.8mm screw to free Micro-USB module for removal using the PH000 headtype
  9. LG Optimus L9 P769 Micro-USB Port Replacement: passo 9, imagem 1 %32 LG Optimus L9 P769 Micro-USB Port Replacement: passo 9, imagem 2 %32
    • Use a small prying tool to detach the Micro-USB circuitry from the case of the phone
  10. LG Optimus L9 P769 Micro-USB Port Replacement: passo 10, imagem 1 %32
    • Comparison showing the Micro-USB module against the empty phone casing
Conclusão
Kayden G
Membro desde: 03/01/17
272 Reputação
Autoria de 2 guias
Equipe
IUPUI, Team S2-G1, Harley Spring 2017 Membro de IUPUI, Team S2-G1, Harley Spring 2017
IUPUI-HARLEY-S17S2G1
Membros da 4
Autoria de 6 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 2
Últimos 30 dias: 10
Duração total: 328
