Ir para o conteúdo principal
LG Optimus L7 P705 SIM Card Slot Replacement
O que você precisa
  1. LG Optimus L7 P705 SIM Card Slot Replacement, Home Button: passo 1, imagem 1 %32 LG Optimus L7 P705 SIM Card Slot Replacement, Home Button: passo 1, imagem 2 %32
    • Insert a plastic opening tool between the seams of the device and pry the back cover away from the phone.
    • Remove the battery and SIM card.
  2. LG Optimus L7 P705 SIM Card Slot Replacement: passo 2, imagem 1 %32
    • Remove the twelve screws using the Phillips 000 screwdriver.
  3. LG Optimus L7 P705 SIM Card Slot Replacement: passo 3, imagem 1 %32
    • Remove bottom plate where the charger port is located.
  4. LG Optimus L7 P705 SIM Card Slot Replacement: passo 4, imagem 1 %32 LG Optimus L7 P705 SIM Card Slot Replacement: passo 4, imagem 2 %32
    • Insert a plastic opening tool between the seams of the device and apply some pressure to lift off the cover.
  5. LG Optimus L7 P705 SIM Card Slot Replacement: passo 5, imagem 1 %32
    • Flip over to the face of the device.
    • Lift off the glass screen (display).
  6. LG Optimus L7 P705 SIM Card Slot Replacement: passo 6, imagem 1 %32
    • Remove the home screen button. Replace as needed.
  7. LG Optimus L7 P705 SIM Card Slot Replacement, SIM Card Slot: passo 7, imagem 1 %32 LG Optimus L7 P705 SIM Card Slot Replacement, SIM Card Slot: passo 7, imagem 2 %32
    • Flip over to the back of the device
    • Using the plastic spudger, lift off the three board-to-board connectors on the left-hand side of the device.
  8. LG Optimus L7 P705 SIM Card Slot Replacement: passo 8, imagem 1 %32
    • Using a plastic spudger, lift off the wire connector at the right bottom of the board.
  9. LG Optimus L7 P705 SIM Card Slot Replacement: passo 9, imagem 1 %32 LG Optimus L7 P705 SIM Card Slot Replacement: passo 9, imagem 2 %32
    • Detach the mount including both the SIM card and the motherboard from the device.
Conclusão
Yanxiang Ding
Membro desde: 01/25/17
101 Reputação
Autoria de 1 guia
Equipe
IUPUI, Team 2-2, Baechle Spring 2017 Membro de IUPUI, Team 2-2, Baechle Spring 2017
IUPUI-BAECHLE-S17S2G2
Membros da 4
Autoria de 3 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 4
Últimos 30 dias: 4
Duração total: 624
