Ir para o conteúdo principal
LG Optimus L7 P705 Display Replacement
O que você precisa
  1. LG Optimus L7 P705 Display Replacement, Display: passo 1, imagem 1 %32 LG Optimus L7 P705 Display Replacement, Display: passo 1, imagem 2 %32
    • Use a plastic opening tool to gently pry the back cover away from the phone by inserting it into the seam around the edges.
    • Once the cover is off, remove the battery and SIM card.
    Pergunte ao FixBot
    Comentar
  2. LG Optimus L7 P705 Display Replacement: passo 2, imagem 1 %32
    • Using a Phillips #000 screwdriver, remove the twelve 3mm screws around the frame, including those near the SIM and SD card slots.
    Pergunte ao FixBot
    Comentar
  3. LG Optimus L7 P705 Display Replacement: passo 3, imagem 1 %32
    • Carefully remove the bottom plastic plate located around the charging port area.
    Pergunte ao FixBot
    Comentar
  4. LG Optimus L7 P705 Display Replacement: passo 4, imagem 1 %32 LG Optimus L7 P705 Display Replacement: passo 4, imagem 2 %32
    • Insert a plastic opening tool along the seam of the phone’s frame and gently apply pressure to lift off the midframe cover.
    Pergunte ao FixBot
    Comentar
  5. LG Optimus L7 P705 Display Replacement: passo 5, imagem 1 %32 LG Optimus L7 P705 Display Replacement: passo 5, imagem 2 %32
    • Flip the phone over so the screen is facing up.
    • Carefully lift and remove the glass screen (display) from the front of the device.
    Pergunte ao FixBot
    Comentar
Conclusão
To reassemble your device, follow these instructions in reverse order. Take your e-waste to an R2 or e-Stewards certified recycler.
8 outras pessoas executaram este guia.
Equipe
USF Tampa, Team 9-1, Leahy Fall 2014 Membro de USF Tampa, Team 9-1, Leahy Fall 2014
USFT-LEAHY-F14S9G1
3 Membros
Autoria de 5 guias
2Comentários do guia
Great tutorial as always on ifixit. Just be mindful of the top clip holding the glass bevel as it can be tricky and is close to circuitry.
Sooty - Responder Compartilhar
Im miles i great this ifixit i'm beginner
Omair Sarip - Responder Compartilhar
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 5
Últimos 30 dias: 23
Ao todo: 5,696
