Ir para o conteúdo principal
LG Optimus G Pro Speaker Replacement
O que você precisa
  1. LG Optimus G Pro Speaker Replacement, Remove Back Cover.: passo 1, imagem 1 %32
    • Make sure before you begin working on your device, that the device is not charging.
    • Once you have access to the phone, there is a small indent on the bottom left side. Use your fingernail or a plastic opening tool to pry from here and pull off the back casing.
  2. LG Optimus G Pro Speaker Replacement, Remove the Battery.: passo 2, imagem 1 %32
    • Once you have properly removed the outer casing, the back should look as so.
    • To remove the battery, pull up from the red mark using your finger. The battery should come up at an angle, and easily be able to be removed.
    • Once the battery is removed you may safely proceed to the next step.
  3. LG Optimus G Pro Speaker Replacement, Screw Removal: passo 3, imagem 1 %32 LG Optimus G Pro Speaker Replacement, Screw Removal: passo 3, imagem 2 %32
    • Make sure you remove the battery first. You will see that there are 14 screws on the back of the inner case. Use the Phillips head screwdriver to remove each of the screws, make sure to put the screws in a safe place where they will not get lost.
  4. LG Optimus G Pro Speaker Replacement, Remove Cover: passo 4, imagem 1 %32
    • Once you have removed all the screws, you can begin removing the inside cover.
    • Insert the opening tool using a sliding motion into one of the corners and move it along the edges of the inside cover. This will loosen the edges and the inside cover will pry apart from the shell.
  5. LG Optimus G Pro Speaker Replacement, Completion: passo 5, imagem 1 %32
    • The inner cover is now removed, you now have access to the many parts on the inside of the phone.
  6. LG Optimus G Pro Speaker Replacement, Speaker Removal.: passo 6, imagem 1 %32 LG Optimus G Pro Speaker Replacement, Speaker Removal.: passo 6, imagem 2 %32
    • The inner side of the inside cover houses the speaker module.
    • Use the plastic opening tool to pry the connection between the inner side and the speaker.
  7. LG Optimus G Pro Speaker Replacement, Completetion: passo 7, imagem 1 %32
    • You now have removed the speaker for an easy replacement.
Conclusão
Wesley Pate
Membro desde: 09/25/14
1.641 Reputação
Autoria de 7 guias
Equipe
USF Tampa, Team 15-5, Remmell Fall 2014 Membro de USF Tampa, Team 15-5, Remmell Fall 2014
USFT-REMMELL-F14S15G5
Membros da 3
Autoria de 7 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 1
Duração total: 1,625
