Ir para o conteúdo principal
LG Optimus G Battery Replacement
O que você precisa
  1. LG Optimus G Battery Replacement, Remove the simcard: passo 1, imagem 1 %32 LG Optimus G Battery Replacement, Remove the simcard: passo 1, imagem 2 %32
    • SIM eject tool
  2. LG Optimus G Battery Replacement, Remove the back cover: passo 2, imagem 1 %32 LG Optimus G Battery Replacement, Remove the back cover: passo 2, imagem 2 %32
    • Remove the 2 screws holding the back cover using a T5 screwdriver.
    • Use a guitar pick or a plastic opening tool to free the clips on the top and each side of the back cover.
    • Use an opening pick to pry off the rear case.
  3. LG Optimus G Battery Replacement, Removing the battery: passo 4, imagem 1 %32 LG Optimus G Battery Replacement, Removing the battery: passo 4, imagem 2 %32
    • Remove the tape over the battery, the screws and the antenna connector cord.
    • Be careful removing the golden tape because it is below the antenna connector cord.
  4. LG Optimus G Battery Replacement: passo 5, imagem 1 %32 LG Optimus G Battery Replacement: passo 5, imagem 2 %32
    • Remove the the screws securing the battery cable connector.
    • Disconnect the battery cable.
  5. LG Optimus G Battery Replacement: passo 6, imagem 1 %32
    • The battery is held down by some adhesive.
    • Carefully heat the battery to loosen the adhesive holding it to the case.
  6. LG Optimus G Battery Replacement: passo 7, imagem 1 %32 LG Optimus G Battery Replacement: passo 7, imagem 2 %32
    • Pry the battery up from the case.
    • Be very careful not to puncture the battery when prying. Use blunt plastic tools.
  7. LG Optimus G Battery Replacement: passo 8, imagem 1 %32 LG Optimus G Battery Replacement: passo 8, imagem 2 %32 LG Optimus G Battery Replacement: passo 8, imagem 3 %32
    • The battery is removed.
    • Replace the battery with a new one.
Conclusão
7 outras pessoas executaram este guia.
Eneider Colina
Membro desde: 09/20/13
2.370 Reputação
Autoria de 9 guias
Equipe
Comunidad para traductores de español Membro de Comunidad para traductores de español
Community
Membros da 29
Autoria de 332 guias
5 comentários
“Heat gun”is too vague. So is IR thermometer. What temperature to soften adhesive? How would I know if I was buying the right things?
Deep - Responder
I’m not using a heat gun, it´s a hairdryer; on this case the hairdryer hardly exceeds the 60°C and that is enough to remove the battery. If you want to buy a heat gun you must be careful not to use more than 50 °
Eneider Colina - Responder
Where do you suggest ordering a replacement battery from?
snack le - Responder
you can search it on Amazon and buy directly from LG.
Eneider Colina -
Thank you so much for this wonderful article it helped me replace my battery. I bought my replacement battery from here:-
https://www.phonepartworld.com/LG/LG-Opt...
ricksanchez - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 1
Últimos 30 dias: 14
Duração total: 5,178
