Introdução
Replace your screen if you have broken the screen itself or if the touchscreen has become unresponsive.
O que você precisa
Use the opening on the right side of the phone to pull off the plastic back cover.
Remove the 6 screws using a size PH00 Phillips head screwdriver, and a plastic opening tool to fully remove the back panel.
4 outras pessoas executaram este guia.
