Ir para o conteúdo principal
LG Optimus F60 Speaker Replacement
O que você precisa
  1. LG Optimus F60 Speaker Replacement, Battery: passo 1, imagem 1 %32 LG Optimus F60 Speaker Replacement, Battery: passo 1, imagem 2 %32 LG Optimus F60 Speaker Replacement, Battery: passo 1, imagem 3 %32
    • Hold the phone in your hand and position the small plastic opening tool or your finger under the lip of the phone by the USB port.
    • Pry or lift up on the indent with the opening tool.
    • Remove the back panel.
  2. LG Optimus F60 Speaker Replacement: passo 2, imagem 1 %32 LG Optimus F60 Speaker Replacement: passo 2, imagem 2 %32 LG Optimus F60 Speaker Replacement: passo 2, imagem 3 %32
    • Place the small plastic opening tool or your finger at the indentation at the base of the battery.
    • Pry upwards or lift with your finger and remove battery.
  3. LG Optimus F60 Speaker Replacement, Speaker: passo 3, imagem 1 %32 LG Optimus F60 Speaker Replacement, Speaker: passo 3, imagem 2 %32 LG Optimus F60 Speaker Replacement, Speaker: passo 3, imagem 3 %32
    • Use the Phillips #000 screwdriver to remove eight screws.
  4. LG Optimus F60 Speaker Replacement: passo 4, imagem 1 %32 LG Optimus F60 Speaker Replacement: passo 4, imagem 2 %32
    • Insert the iFixit opening tool in the indentation.
    • Pry the plastic using the opening tool to remove the lower back panel.
    • Remove the back panel from the device.
  5. LG Optimus F60 Speaker Replacement: passo 5, imagem 1 %32 LG Optimus F60 Speaker Replacement: passo 5, imagem 2 %32 LG Optimus F60 Speaker Replacement: passo 5, imagem 3 %32
    • Start at the changing port, and continue to pry at the edges until loose enough to remove.
  6. LG Optimus F60 Speaker Replacement: passo 6, imagem 1 %32 LG Optimus F60 Speaker Replacement: passo 6, imagem 2 %32 LG Optimus F60 Speaker Replacement: passo 6, imagem 3 %32
    Ferramenta utilizada nesse passo:
    Comprar
    • Gently pry the foam seal from around the speaker.
    • Pry out speaker using tweezers.
    • Remove and replace the speaker.
Conclusão
3 outras pessoas executaram este guia.
Mohammad Mohammad
Membro desde: 03/25/19
451 Reputação
Autoria de 3 guias
Equipe
IUPUI, Team S2-G5, Henning Spring 2019 Membro de IUPUI, Team S2-G5, Henning Spring 2019
IUPUI-HENNING-S19S2G5
Membros da 3
Autoria de 3 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 1
Últimos 30 dias: 7
Duração total: 96
