Ir para o conteúdo principal
LG Optimus Exceed 2 Screen Replacement
Guia arquivado
Este guia é mantido exclusivamente para fins históricos. Use a versão atualizada do guia para executar o reparo.
O que você precisa
  1. LG Optimus Exceed 2 Screen Replacement, Battery: passo 1, imagem 1 %32 LG Optimus Exceed 2 Screen Replacement, Battery: passo 1, imagem 2 %32
    • Flip the device over and remove the back covering.
  2. LG Optimus Exceed 2 Screen Replacement: passo 2, imagem 1 %32
    • Push on the top of the battery downward and pull the battery off of the device.
  3. LG Optimus Exceed 2 Screen Replacement, Rear Camera: passo 3, imagem 1 %32 LG Optimus Exceed 2 Screen Replacement, Rear Camera: passo 3, imagem 2 %32 LG Optimus Exceed 2 Screen Replacement, Rear Camera: passo 3, imagem 3 %32
    • Remove the eleven 4mm screws using a Philips head screw driver.
  4. LG Optimus Exceed 2 Screen Replacement: passo 4, imagem 1 %32 LG Optimus Exceed 2 Screen Replacement: passo 4, imagem 2 %32 LG Optimus Exceed 2 Screen Replacement: passo 4, imagem 3 %32
    • Insert the plastic opening tool into the side of the device and pry off silver covering. Push up against the back covering when the tool is inserted to detach from the phone.
    • Make sure to detach all sides of silver covering before lifting it off the phone.
  5. LG Optimus Exceed 2 Screen Replacement: passo 5, imagem 1 %32 LG Optimus Exceed 2 Screen Replacement: passo 5, imagem 2 %32
    • Using the prying tool detach the connector on the device.
    • Insert the plastic opening tool underneath the connector and push tool down to lift the connector from the device.
  6. LG Optimus Exceed 2 Screen Replacement: passo 6, imagem 1 %32 LG Optimus Exceed 2 Screen Replacement: passo 6, imagem 2 %32
    • Using tweezers lift the camera off of the device.
    • To do so grasp the camera gently with the tweezers and pull the camera up out of the device.
  7. LG Optimus Exceed 2 Screen Replacement, Motherboard: passo 7, imagem 1 %32 LG Optimus Exceed 2 Screen Replacement, Motherboard: passo 7, imagem 2 %32
    • Disconnect the remaining ribbon plugs and connectors. (Only remove the highlighted cables for the removal of the logic board.)
  8. LG Optimus Exceed 2 Screen Replacement: passo 8, imagem 1 %32 LG Optimus Exceed 2 Screen Replacement: passo 8, imagem 2 %32
    • Push the blue lifting tool up underneath the logic board and pull it upwards removing it from the device.
  9. LG Optimus Exceed 2 Screen Replacement, Screen: passo 9, imagem 1 %32 LG Optimus Exceed 2 Screen Replacement, Screen: passo 9, imagem 2 %32 LG Optimus Exceed 2 Screen Replacement, Screen: passo 9, imagem 3 %32
    • Using a prying tool, carefully remove the silver/ black tape used to hide the screens connectors.
  10. LG Optimus Exceed 2 Screen Replacement: passo 10, imagem 1 %32 LG Optimus Exceed 2 Screen Replacement: passo 10, imagem 2 %32 LG Optimus Exceed 2 Screen Replacement: passo 10, imagem 3 %32
    • Using the blue lifting tool carefully remove the screens connectors.
  11. LG Optimus Exceed 2 Screen Replacement: passo 11, imagem 1 %32 LG Optimus Exceed 2 Screen Replacement: passo 11, imagem 2 %32 LG Optimus Exceed 2 Screen Replacement: passo 11, imagem 3 %32
    • Flip the device so the screen faces you. Using a prying tool, at the corners on the screen begin to pry off the screen. (It will sound like tape being removed.) Avoid scratching the device with the prying tool.
  12. LG Optimus Exceed 2 Screen Replacement: passo 12, imagem 1 %32
    • Pull the screen off of the body of the device. (Mind the circuits when removing the screen. The home button is likely to fall off. )
Conclusão
Carl Dorvilus
Membro desde: 03/10/16
708 Reputação
Autoria de 6 guias
Equipe
UMass Dartmouth, Team 4-4, Catania Spring 2016 Membro de UMass Dartmouth, Team 4-4, Catania Spring 2016
UMASSD-CATANIA-S16S4G4
Membros da 3
Autoria de 6 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 0
Duração total: 116
