Ir para o conteúdo principal
LG Optimus 3D Battery Replacement
  1. LG Optimus 3D Battery Replacement, Back Cover Removal: passo 1, imagem 1 %32 LG Optimus 3D Battery Replacement, Back Cover Removal: passo 1, imagem 2 %32
    • Pry the back cover off of the phone with your fingernail. There is a notch located at the bottom of the phone for improved leverage.
  2. LG Optimus 3D Battery Replacement, Battery Removal: passo 2, imagem 1 %32 LG Optimus 3D Battery Replacement, Battery Removal: passo 2, imagem 2 %32 LG Optimus 3D Battery Replacement, Battery Removal: passo 2, imagem 3 %32
    • The battery is the large black rectangle towards the bottom half of the phone.
    • There is a semi-circular notch at the bottom edge of the battery. Press against and up on the battery to pop it out.
Conclusão
Dale Pearson
Membro desde: 09/22/14
784 Reputação
Autoria de 6 guias
Equipe
USF Tampa, Team 10-6, Brown Fall 2014 Membro de USF Tampa, Team 10-6, Brown Fall 2014
USFT-BROWN-F14S10G6
Membros da 3
Autoria de 6 guias
Um comentário
it’s available stock
Raja Ali - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 3
Últimos 30 dias: 4
Duração total: 670
