Ir para o conteúdo principal
LG Neon GT 365 Speaker Replacement
O que você precisa
  1. LG Neon GT 365 Speaker Replacement, Speaker: passo 1, imagem 1 %32 LG Neon GT 365 Speaker Replacement, Speaker: passo 1, imagem 2 %32
    • With one hand, push the rectangular button located on the back top-side of the phone.
    • With your other hand, remove the rear cover.
  2. LG Neon GT 365 Speaker Replacement: passo 2, imagem 1 %32
    • Remove 5 screws, 1 from each corner of the phone and 1 from the center-right of the phone.
  3. LG Neon GT 365 Speaker Replacement: passo 3, imagem 1 %32 LG Neon GT 365 Speaker Replacement: passo 3, imagem 2 %32
    • Now pull off the rear casing, using an opening tool. **Buttons for volume and pictures may fall out**
  4. LG Neon GT 365 Speaker Replacement: passo 4, imagem 1 %32
    • Once you have removed the rear casing flip it over to see a small circular metal piece with 2 gold springs sticking out of the bottom. That is the speaker.
    • Opposite the 2 small gold springs there will be a small black tab attached to the speaker sitting in a groove. Using tweezers or a small tipped screwdriver lift up on the tab to pop the speaker out.
  5. LG Neon GT 365 Speaker Replacement: passo 5, imagem 1 %32
    • Replace the broken speaker with a new one (make sure to line up the tab with the groove). Push firmly into place. Follow reverse instructions to put the rear casing and back cover on.
Conclusão
kristie
Membro desde: 10/23/13
538 Reputação
Autoria de 5 guias
Equipe
UMass Dartmouth, Team 2-1, Gulbrandsen Fall 2013 Membro de UMass Dartmouth, Team 2-1, Gulbrandsen Fall 2013
UMASSD-GULBRANDSEN-F13S2G1
Membros da 4
Autoria de 10 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 1
Duração total: 224
