Ir para o conteúdo principal
LG Muziq LX570 Camera Replacement
O que você precisa
  1. LG Muziq LX570 Camera Replacement, Front Case: passo 1, imagem 1 %32 LG Muziq LX570 Camera Replacement, Front Case: passo 1, imagem 2 %32
    • Use a spudger to remove the two screw covers below display.
    • Use a screw driver to remove the four Phillips #00 (3.3mm) screws at corners of the display.
  2. LG Muziq LX570 Camera Replacement: passo 2, imagem 1 %32 LG Muziq LX570 Camera Replacement: passo 2, imagem 2 %32 LG Muziq LX570 Camera Replacement: passo 2, imagem 3 %32
    • Caution: Wires and ribbon connect the front case to the main body. Exhibit care when separating front case from the main body as to not break the connections.
    • Note: Side buttons may fall out when removing the front case. Do not misplace them.
    • Note: Each side button will only fit in the side that it came from.
    • Insert a spudger between the black and grey casings and gently spread them apart.
    • Work around the device gradually, opening the gap further.
  3. LG Muziq LX570 Camera Replacement: passo 3, imagem 1 %32 LG Muziq LX570 Camera Replacement: passo 3, imagem 2 %32 LG Muziq LX570 Camera Replacement: passo 3, imagem 3 %32
    • Caution: The wires and ribbon connector can break easily. Exhibit care when removing them.
    • Use the spudger and lift upward to disconnect the ribbon from the main part of the phone.
    • Carefully remove any parts stuck to the front case such as speakers.
  4. LG Muziq LX570 Camera Replacement, Camera: passo 4, imagem 1 %32 LG Muziq LX570 Camera Replacement, Camera: passo 4, imagem 2 %32 LG Muziq LX570 Camera Replacement, Camera: passo 4, imagem 3 %32
    • Disconnect the ribbons on both sides of the camera by prying them up with a spudger.
  5. LG Muziq LX570 Camera Replacement: passo 5, imagem 1 %32 LG Muziq LX570 Camera Replacement: passo 5, imagem 2 %32
    • Hold the wiring out of the way and pull up with a spudger behind the camera.
    • The camera unit should come unglued and separate from the phone.
Conclusão
Braden Burk
Membro desde: 01/22/12
1 Reputação
Autoria de 5 guias
Equipe
Cal Poly, Team 3-29, Amido Winter 2012 Membro de Cal Poly, Team 3-29, Amido Winter 2012
CPSU-AMIDO-W12S3G29
Membros da 4
Autoria de 14 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 3
Duração total: 734
