Ir para o conteúdo principal
LG Motion 4G MS770 Rear Facing Camera Replacement
O que você precisa
  1. LG Motion 4G MS770 Rear Facing Camera Replacement, Remove the phone's back cover.: passo 1, imagem 1 %32
    • Use a plastic opening tool to remove the back cover.
  2. LG Motion 4G MS770 Rear Facing Camera Replacement, Remove the battery.: passo 2, imagem 1 %32
    • Use a plastic opening tool to remove the battery, lifting from the bottom right corner.
  3. LG Motion 4G MS770 Rear Facing Camera Replacement, Remove screws.: passo 3, imagem 1 %32
    • Use a Phillips #00 Screwdriver to remove all eight 4mm screws.
  4. LG Motion 4G MS770 Rear Facing Camera Replacement: passo 4, imagem 1 %32 LG Motion 4G MS770 Rear Facing Camera Replacement: passo 4, imagem 2 %32
    • Use a plastic opening tool to remove the back trim by working around all of the edges.
  5. LG Motion 4G MS770 Rear Facing Camera Replacement: passo 5, imagem 1 %32 LG Motion 4G MS770 Rear Facing Camera Replacement: passo 5, imagem 2 %32
    • Remove the volume buttons from the side.
  6. LG Motion 4G MS770 Rear Facing Camera Replacement, Speaker: passo 6, imagem 1 %32 LG Motion 4G MS770 Rear Facing Camera Replacement, Speaker: passo 6, imagem 2 %32
    • Use a plastic opening tool to lift the speaker off by prying under the silver square as shown.
    • Note: There is a small tab underneath the speaker that will be lifted off when the speaker is removed.
  7. LG Motion 4G MS770 Rear Facing Camera Replacement, Rear Facing Camera: passo 7, imagem 1 %32
    • Pry slightly underneath the tab attached to the camera until it pops off.
  8. LG Motion 4G MS770 Rear Facing Camera Replacement: passo 8, imagem 1 %32
    • Use tweezers to remove the camera, you will need to use some force as it is glued on.
Conclusão
Uma outra pessoa concluiu este guia.
Zarna Patel
Membro desde: 10/08/14
320 Reputação
Autoria de 2 guias
Equipe
USF Tampa, Team 14-1, Leahy Fall 2014 Membro de USF Tampa, Team 14-1, Leahy Fall 2014
USFT-LEAHY-F14S14G1
Membros da 3
Autoria de 10 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 4
Últimos 30 dias: 5
Duração total: 221
