Introdução
If phone will not turn on or has system errors and the troubleshooting did not help then replace the broken motherboard with a new one.
O que você precisa
Use a plastic opening tool to remove the battery, lifting from the bottom right corner.
Use a plastic opening tool to lift the speaker off by prying under the silver square as shown.
Pry slightly underneath the tab attached to the camera until it pops off.
Pry off the circled tabs using a plastic opening tool to release the motherboard.
7 outras pessoas executaram este guia.
