Ir para o conteúdo principal
LG Monitor 27MN60T Disassembly
  1. LG Monitor 27MN60T Disassembly, LG Monitor 27MN60T Disassembly: passo 1, imagem 1 %32 LG Monitor 27MN60T Disassembly, LG Monitor 27MN60T Disassembly: passo 1, imagem 2 %32 LG Monitor 27MN60T Disassembly, LG Monitor 27MN60T Disassembly: passo 1, imagem 3 %32
    • Back panel is held on with 30 plastic clips. The clip locations are circled in red.
    • 10 across the bottom. The clip sticks out from the black frame into the white back.
    • 8 across the top. The clip faces towards the center of the monitor. The clip sticks out from the white back into the black frame,
    • 6 along left and right side. The clip faces towards the center of the monitor. The clip sticks out from the white back into the black frame.
    • There is a single screw near the HDMI connector
    • Use a thin metal tool (jimmy) to slide between the white back and black frame to release the clips.
  2. LG Monitor 27MN60T Disassembly: passo 2, imagem 1 %32 LG Monitor 27MN60T Disassembly: passo 2, imagem 2 %32
    • Two more pictures showing disassembled monitor
Conclusão
Alan Nishioka
Membro desde: 07/17/11
3.585 Reputação
Autoria de 8 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 12
Últimos 30 dias: 29
Ao todo: 5,025
