Ir para o conteúdo principal
LG Leon LTE Motherboard Replacement
O que você precisa
  1. LG Leon LTE Motherboard Replacement, Motherboard: passo 1, imagem 1 %32 LG Leon LTE Motherboard Replacement, Motherboard: passo 1, imagem 2 %32
    • Turn the phone over so the back is facing upward.
  2. LG Leon LTE Motherboard Replacement: passo 2, imagem 1 %32 LG Leon LTE Motherboard Replacement: passo 2, imagem 2 %32 LG Leon LTE Motherboard Replacement: passo 2, imagem 3 %32
    • Insert your opening tool in the incision at the bottom center of the phone.
    • Push upward with the opening tool to pry the back of the phone open.
    • Remove the back completely and set aside.
  3. LG Leon LTE Motherboard Replacement: passo 3, imagem 1 %32 LG Leon LTE Motherboard Replacement: passo 3, imagem 2 %32 LG Leon LTE Motherboard Replacement: passo 3, imagem 3 %32
    • Using the Phillips #0 screwdriver, unscrew the 8 screws that secure the back frame to the body of the phone.
    • Remember to put the screws in a safe place so you don't lose them.
    • Once all screws are removed, use the opening tool to pry the back frame of the phone free.
  4. LG Leon LTE Motherboard Replacement: passo 4, imagem 1 %32 LG Leon LTE Motherboard Replacement: passo 4, imagem 2 %32
    • Using the opening tool, gently pry the phone's earpiece off. Set aside.
    • Separate the old motherboard from the phone fixture by pulling it apart.
    • Gently press the replacement motherboard into the phone fixture.
Conclusão
Geul Kim
Membro desde: 01/29/18
604 Reputação
Autoria de 5 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 2
Últimos 30 dias: 6
Duração total: 688
