Introdução
Use this guide to remove the LG LX150's sceen.
O que você precisa
Use the spudger to pry out the indicated rubber squares.
Use the #0 Phillips screwdriver to take out the revealed screws.
Gently loosen the screen from its adhesive by pressing around the screen's rear perimeter with a spudger. Place upward pressure in crevices between face plate and screen.
Carefully use both thumbs and apply pressure to the back of the screen to pop out.
Uma outra pessoa concluiu este guia.
