Este guia tem alterações mais recentes. Mudar para a última versão não verificada.
Introdução
If your keypad is faulty and/or not working, you will want to replace it using this guide.
O que você precisa
First locate the button and the bottom of the cover where the arrow is. Press down on the button.
While pushing down on the button, slide the cover up towards the hinge until the cover comes off.
The battery will be visible after removing the back cover.
Remove the 7 phillips screws indicated by the red arrows using the phillips #0 screwdriver.
Insert the flat end of the spudger in-between the black and blue phone casing on the side of the phone and split the the blue and black apart. Work your way around the perimeter of the cover, loosening all corners.
Uma outra pessoa concluiu este guia.
