Pular para o conteúdo principal
Introdução
This guide will help you replace the logic board.
  1. Make sure you remove the battery by lifting the tab on the back of the phone before opening the case.
    • Make sure you remove the battery by lifting the tab on the back of the phone before opening the case.
    • Poke out rubber covers using a spudger or pointy object, such as a thumb tack.
  2. Use a T6 torx screwdriver to unscrew the 6 screws that hold the back casing on.
    • Use a T6 torx screwdriver to unscrew the 6 screws that hold the back casing on.
  3. Use IPod opening tool to separate back housing.
    • Use IPod opening tool to separate back housing.
    • There are two tabs located on either side of the phone.
  4. PC Laptop Batteries
    An easy fix for a big power boost.
    Comprar agora
    PC Laptop Batteries
    Comprar agora
  5. Separate the back housing from the phone.
    • Separate the back housing from the phone.
    • Be careful not to rip out the wire (highlighted in yellow) when separating the back housing.
  6. Use a spudger to disconnect antenna wire.
    • Use a spudger to disconnect antenna wire.
  7. Use the IPod opening tool to pop out the logic board.
    • Use the IPod opening tool to pop out the logic board.
  8. Use the IPod opening tool to disconnect the main ribbon.
    • Use the IPod opening tool to disconnect the main ribbon.
  9. Once the ribbon is detached, remove the logic board and replace if necessary.
    • Once the ribbon is detached, remove the logic board and replace if necessary.
Conclusão
Joshua Herrmann
Membro desde: 16-04-2010
8 reputação
8 Guias de autoria
Equipe
Cal Poly, Team 6-14, Maness Spring 2010 Membro de Cal Poly, Team 6-14, Maness Spring 2010
CPSU-MANESS-S10S6G14
4 Membros
16 Guias de autoria
Adicionar comentário
Visualizar Estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 0
Todo: 1,153
