Ir para o conteúdo principal
LG L1200 Camera Replacement
O que você precisa
  1. LG L1200 Camera Replacement, Inner LCD Screen: passo 1, imagem 1 %32
    • Make sure you remove the battery by lifting the tab on the back of the phone before opening the case.
    • Flip open the phone and locate the four screw covers.
  2. LG L1200 Camera Replacement: passo 2, imagem 1 %32
    • Remove all four screw covers by using an IPod opening tool. They should come off relatively easy.
  3. LG L1200 Camera Replacement: passo 3, imagem 1 %32
    • Using a T6 Torx screwdriver, remove all four screws.
  4. LG L1200 Camera Replacement: passo 4, imagem 1 %32 LG L1200 Camera Replacement: passo 4, imagem 2 %32 LG L1200 Camera Replacement: passo 4, imagem 3 %32
    • Once the screws are removed, use an IPod opening tool to separate the front cover from the inner screen cover.
    • Run the Ipod opening tool down both sides,disconnecting the tabs that hold the covers together.
  5. LG L1200 Camera Replacement: passo 5, imagem 1 %32 LG L1200 Camera Replacement: passo 5, imagem 2 %32
    • Pull the inner screen cover towards you and up in order to separate it from the front cover.
  6. LG L1200 Camera Replacement: passo 6, imagem 1 %32
    • Remove the tape from the bottom of the LCD screen.
  7. LG L1200 Camera Replacement: passo 7, imagem 1 %32 LG L1200 Camera Replacement: passo 7, imagem 2 %32 LG L1200 Camera Replacement: passo 7, imagem 3 %32
    • Carefully lift the LCD screen and peel it from the gold ribbon. The sticky connection runs all the way around the LCD screen.
  8. LG L1200 Camera Replacement: passo 8, imagem 1 %32 LG L1200 Camera Replacement: passo 8, imagem 2 %32 LG L1200 Camera Replacement: passo 8, imagem 3 %32
    • Flip the screen over so that you can see the outer LCD screen and the circuit board.
    • Insert spudger in the bottom right corner.
    • Lift up and move the spudger across the bottom.
    • The third photo is rotated 180 degrees.
  9. LG L1200 Camera Replacement: passo 9, imagem 1 %32 LG L1200 Camera Replacement: passo 9, imagem 2 %32
    • Use the pointy side of the spudger to peel off the interior tape.
    • Flip the assembly over and peel the circuit board from the screen.
  10. LG L1200 Camera Replacement: passo 10, imagem 1 %32 LG L1200 Camera Replacement: passo 10, imagem 2 %32
    • Use the spudger to remove the LCD screen from its backing.
  11. LG L1200 Camera Replacement, Camera: passo 11, imagem 1 %32
    • Carefully slide the spudger behind the main ribbon in order to separate it from the inside cover of the phone.
  12. LG L1200 Camera Replacement: passo 12, imagem 1 %32 LG L1200 Camera Replacement: passo 12, imagem 2 %32
    • Use a spudger to pop off the camera ribbon from the main ribbon. The camera component should separate entirely.
Conclusão
Joshua Herrmann
Membro desde: 04/16/10
8 Reputação
Autoria de 8 guias
Equipe
Cal Poly, Team 6-14, Maness Spring 2010 Membro de Cal Poly, Team 6-14, Maness Spring 2010
CPSU-MANESS-S10S6G14
Membros da 4
Autoria de 16 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 3
Duração total: 1,230
