Ir para o conteúdo principal
LG KP100 SIM Card Replacement
  1. LG KP100 SIM Card Replacement, Battery: passo 1, imagem 1 %32 LG KP100 SIM Card Replacement, Battery: passo 1, imagem 2 %32
    • Begin by taking the back battery cover off.
    • Put your index finger on the white notch and apply pressure.
    • While applying pressure, move your hand backwards to slide the battery cover off of the body of the phone.
  2. LG KP100 SIM Card Replacement: passo 2, imagem 1 %32 LG KP100 SIM Card Replacement: passo 2, imagem 2 %32
    • Remove the battery.
    • Put your index finger in the notch above the battery near the top of the casing.
    • While applying pressure against the battery, lift up and take out the battery.
  3. LG KP100 SIM Card Replacement, SIM Card: passo 3, imagem 1 %32 LG KP100 SIM Card Replacement, SIM Card: passo 3, imagem 2 %32 LG KP100 SIM Card Replacement, SIM Card: passo 3, imagem 3 %32
    • Remove the SIM card from its housing.
    • Put your finger in the provided notch below the SIM card and begin to push the SIM card towards the top of the device.
    • After it is out of the metal housing, it is free to be removed.
Conclusão
Preston Brown
Membro desde: 04/12/12
28 Reputação
Autoria de 5 guias
Equipe
Cal Poly, Team 6-20, Amido Spring 2012 Membro de Cal Poly, Team 6-20, Amido Spring 2012
CPSU-AMIDO-S12S6G20
Membros da 4
Autoria de 10 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 7
Últimos 30 dias: 17
Duração total: 1,296
