Ir para o conteúdo principal
LG K7 Volume & On/Off Buttons Replacement
O que você precisa
  1. LG K7 Volume & On/Off Buttons Replacement, Volume & On/Off Buttons: passo 1, imagem 1 %32 LG K7 Volume & On/Off Buttons Replacement, Volume & On/Off Buttons: passo 1, imagem 2 %32
    • Remove the back cover using a plastic opening tool.
    • Remove the battery using a plastic opening tool.
  2. LG K7 Volume & On/Off Buttons Replacement: passo 2, imagem 1 %32
    • Remove the nine 4mm Phillips #000 screws.
    • The cover should lift off easily once the screws are out.
    • Be gentle with the frame when removing it. The plastic is very thin and can easily break.
  3. LG K7 Volume & On/Off Buttons Replacement: passo 3, imagem 1 %32
    • Pry off the silver button housing using the plastic opening tool.
  4. LG K7 Volume & On/Off Buttons Replacement: passo 4, imagem 1 %32
    • Separate the screen from the rest of the phone using the plastic opening tool.
    • The frame is held to the rest of the phone with plastic tabs. Release each tab one at a time around the phone for the easiest removal.
    • Do not bend the outer frame or screen when separating them. This will severely damage the phone.
  5. LG K7 Volume & On/Off Buttons Replacement: passo 5, imagem 1 %32 LG K7 Volume & On/Off Buttons Replacement: passo 5, imagem 2 %32 LG K7 Volume & On/Off Buttons Replacement: passo 5, imagem 3 %32
    • Peel off the orange cable using a plastic opening tool.
  6. LG K7 Volume & On/Off Buttons Replacement: passo 6, imagem 1 %32
    • Remove the volume/power button cable from the rest of the phone using the plastic opening tool to break the adhesive.
Conclusão
Uma outra pessoa concluiu este guia.
Jack Lepkowski
Membro desde: 11/07/19
136 Reputação
Autoria de 1 guia
Equipe
IUPUI, Team S3-G2, Harley Fall 2019 Membro de IUPUI, Team S3-G2, Harley Fall 2019
IUPUI-HARLEY-F19S3G2
Membros da 3
Autoria de 4 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 4
Últimos 7 dias: 4
Últimos 30 dias: 12
Duração total: 504
