Ir para o conteúdo principal
LG K7 Rear Facing Camera Replacement
O que você precisa
  1. LG K7 Rear Facing Camera Replacement, Battery: passo 1, imagem 1 %32 LG K7 Rear Facing Camera Replacement, Battery: passo 1, imagem 2 %32
    • Place a fingernail in slot at in the bottom edge of the phone.
    • Pull up on the back panel while holding down the rest of the phone steady with your hand.
    • Do not to pull too hard on the back panel or you may break it.
  2. LG K7 Rear Facing Camera Replacement: passo 2, imagem 1 %32 LG K7 Rear Facing Camera Replacement: passo 2, imagem 2 %32
    • Place a fingernail in the slot at the bottom edge of the battery.
    • Pull the battery out.
  3. LG K7 Rear Facing Camera Replacement, Rear Facing Camera: passo 3, imagem 1 %32 LG K7 Rear Facing Camera Replacement, Rear Facing Camera: passo 3, imagem 2 %32 LG K7 Rear Facing Camera Replacement, Rear Facing Camera: passo 3, imagem 3 %32
    • Remove the 9 frame screws with a JIS #00 screwdriver.
    • The bottom three screws release the port cover at the bottom of the phone. The cover should lift off easily once the screws are out.
    • Pop the camera button frame off with a spudger. The home button should come off along with the frame.
    • Be gentle with the frame when removing it. The plastic is very thin and can easily break.
  4. LG K7 Rear Facing Camera Replacement: passo 4, imagem 1 %32 LG K7 Rear Facing Camera Replacement: passo 4, imagem 2 %32
    • Use a plastic opening tool to separate the screen from the outer frame.
    • Do not to bend the outer frame or the screen to when separating them. This can severely damage the phone.
  5. LG K7 Rear Facing Camera Replacement: passo 5, imagem 1 %32
    • Insert the edge of a plastic opening tool underneath the camera connector that is attached to the camera by a flat, thin, and flexible sheet.
    • Slowly lever the connector free by pressing down on the opening tool's handle. The connector should be fairly solid and pop out by levering just one edge.
    • Be careful not to break or bend the connector or any part of the device you may be levering against.
Conclusão
Uma outra pessoa concluiu este guia.
James Ngo
Membro desde: 01/19/18
461 Reputação
Autoria de 4 guias
Equipe
Cal Poly, Team S21-G5, Banghart Winter 2018 Membro de Cal Poly, Team S21-G5, Banghart Winter 2018
CPSU-BANGHART-W18S21G5
Membros da 4
Autoria de 8 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 6
Duração total: 423
