Introdução
The home button cable connects the home button to the rest of the phone. It can stop working for a number of reasons but the main two are shock and wear. It can be replaced in less than 5 minutes with the guide below.
Peças
Nenhum componente especificado.
  1. Place a fingernail in slot at in the bottom edge of the phone. Pull up on the back panel while holding down the rest of the phone steady with your hand.
    • Place a fingernail in slot at in the bottom edge of the phone.
    • Pull up on the back panel while holding down the rest of the phone steady with your hand.
    • Do not to pull too hard on the back panel or you may break it.
  2. Place a fingernail in the slot  at the bottom edge of the battery. Pull the battery out.
    • Place a fingernail in the slot at the bottom edge of the battery.
    • Pull the battery out.
  3. Kits de reparo de android
    A new screen or battery is one kit away.
    Comprar agora
    Comprar agora
  4. Remove the nine frame screws with a JIS #00 screwdriver. The bottom three screws release the port cover at the bottom of the phone. The cover should lift off easily once the screws are out. Pop the camera button frame off with a spudger. The home button should come off along with the frame.
    • Remove the nine frame screws with a JIS #00 screwdriver.
    • The bottom three screws release the port cover at the bottom of the phone. The cover should lift off easily once the screws are out.
    • Pop the camera button frame off with a spudger. The home button should come off along with the frame.
    • Be gentle with the frame when removing it. The plastic is very thin and can easily break.
  5. Use a plastic opening tool to separate the screen from the outer frame. The frame is held to the rest of the phone with plastic tabs. Release each tab one at a time around the phone for easiest removal.
    • Use a plastic opening tool to separate the screen from the outer frame.
    • The frame is held to the rest of the phone with plastic tabs. Release each tab one at a time around the phone for easiest removal.
    • Do not bend the outer frame or the screen when separating them because this will severely damage the phone.
  6. The home button cable is attached to both the front and the back  of the outer frame with adhesive. Orient the frame so that where the screen would be is facing you. Peel back the black rubber tab covering the wire. Detach the cable from the frame with a plastic opening tool and let hang. Flip the phone over and detach the button sensor part of the cable from the frame with a spudger.
    • The home button cable is attached to both the front and the back of the outer frame with adhesive. Orient the frame so that where the screen would be is facing you. Peel back the black rubber tab covering the wire.
    • Detach the cable from the frame with a plastic opening tool and let hang.
    • Flip the phone over and detach the button sensor part of the cable from the frame with a spudger.
    • Pull the backside cable through the hole when removing the component.
Conclusão
James Ngo
Membro desde: 19-01-2018
461 Reputation
4 Guias de autoria
Cal Poly, Team S21-G5, Banghart Winter 2018 Membro de Cal Poly, Team S21-G5, Banghart Winter 2018
CPSU-BANGHART-W18S21G5
4 Membros
4 Guias de autoria
0 Comments
Past 24 Hours: 1
Past 7 Days: 3
Past 30 Days: 6
All Time: 391
