Introdução
A malfunctioning headphone jack is often the problem if you are experiencing a lack of audio through headphones. Replacement headphone jacks can be found online.
O que você precisa
Place a fingernail in slot at in the bottom edge of the phone.
Pull up on the back panel while holding down the rest of the phone steady with your hand.
Remove the nine frame screws with a #J00 screwdriver.
Pop the camera button frame off with a spudger. The home button should come off along with the frame.
