Introdução
The charging port allows for the LG K7 to be charged. It can stop working for a number of reasons but the main two are shock and wear. It can be replaced in about 30 minutes with the guide below. A soldering iron will be necessary which should be used with caution.
O que você precisa
Remove the back cover by using the plastic opening tool.
Remove battery by using the plastic opening tool.
Uma outra pessoa concluiu este guia.
