Ir para o conteúdo principal
Introdução
This guide will show you the steps to replace the front-facing camera for the LG K30.
This is a relatively easy fix, but please be sure to go slow and steady when replacing the front-facing camera so that you do not accidentally tear any of the wires or damage the connecting points.
  1. Before disassembling your LG K30, discharge the battery below 25%. A charged lithium-ion battery can catch fire and/or explode if accidentally punctured. Power off your Phone before beginning disassembly.
    • Before disassembling your LG K30, discharge the battery below 25%. A charged lithium-ion battery can catch fire and/or explode if accidentally punctured.
    • Power off your Phone before beginning disassembly.
    • Use the 'Jimmy' and 'Metal Spudger' to slowly pry open the outsides of the back case.
  2. Remove the thirteen 3.4 mm Phillips #00 screws securing the midframe to the display assembly.
    • Remove the thirteen 3.4 mm Phillips #00 screws securing the midframe to the display assembly.
  3. Use a metal spudger or plastic opening tool to pry open the outer cover.
    • Use a metal spudger or plastic opening tool to pry open the outer cover.
  4. Use the flat end  of a spudger to detach the battery connector from the logic board.
    • Use the flat end of a spudger to detach the battery connector from the logic board.
  5. Use a spudger to pry the battery from the phone. There may be an adhesive on the back of the battery and the phone. Pry the battery gently to prevent puncture or damage.
    • Use a spudger to pry the battery from the phone.
    • There may be an adhesive on the back of the battery and the phone. Pry the battery gently to prevent puncture or damage.
    • Do not bend or puncture the battery.
  6. Use the plastic spudger to disconnect the  cable connector.
    • Use the plastic spudger to disconnect the cable connector.
  7. Gently pry out the front-facing camera from the device.
    • Gently pry out the front-facing camera from the device.
Conclusão
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 4
Duração total: 134
