Ir para o conteúdo principal
LG K20 PLUS Vibrator Replacement
O que você precisa
  1. LG K20 PLUS Vibrator Replacement, Remove the back cover and battery: passo 1, imagem 1 %32 LG K20 PLUS Vibrator Replacement, Remove the back cover and battery: passo 1, imagem 2 %32
    • Remove the back cover by inserting a fingernail or opening pick here and disengaging the plastic clips.
    • Lift battery up here
  2. Cuidado: as etapas de 2 a 3 são provenientes de um guia marcado como em andamento.
    LG K20 PLUS Vibrator Replacement, Midframe: passo 2, imagem 1 %32
    • Remove 11 Philips screws.
  3. LG K20 PLUS Vibrator Replacement: passo 3, imagem 1 %32 LG K20 PLUS Vibrator Replacement: passo 3, imagem 2 %32
    • Use fingernails or insert an opening pick into the gap between the digitizer and the midframe and pull the midframe outwards to disengage the plastic clips.
    • Carefully disengage the clips on the bottom as the headphone jack goes through the midframe.
    • Once all the clips have been disengaged, move the midframe outwards and downwards to disengage it from the headphone jack.
  4. LG K20 PLUS Vibrator Replacement, Rear-Facing Camera: passo 4, imagem 1 %32
    • Use a Halberd spudger or an opening pick to disconnect the front camera flex from its connector on the motherboard.
  5. Cuidado: a etapa 5 é proveniente de um guia marcado como em andamento.
    LG K20 PLUS Vibrator Replacement, Motherboard Removal: passo 5, imagem 1 %32
    • Using the tip of a Halberd spudger or an opening pick, disconnect the display flex cable from its socket on the motherboard.
    • Starting from the bottom, insert an opening pick between the motherboard and frame and lever apart.
    • Be careful not to break the long section of the motherboard.
    • The top part of the motherboard is lightly adhered to the frame.
    • After the motherboard is removed, compare the original and replacement part. Some components may already be installed on the replacement display assembly.
  6. LG K20 PLUS Vibrator Replacement, Removing the vibrator: passo 6, imagem 1 %32
    • The vibrator motor is held in with strong adhesive.
    • Insert the tip of a metal spudger on the right side of the vibrator motor and pry it upwards.
Conclusão
Patrick
Membro desde: 05/14/14
6.574 Reputação
Autoria de 21 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 2
Duração total: 239
