Ir para o conteúdo principal
LG K20 PLUS Midframe Replacement
O que você precisa
  1. LG K20 PLUS Midframe Replacement, Remove the back cover and battery: passo 1, imagem 1 %32 LG K20 PLUS Midframe Replacement, Remove the back cover and battery: passo 1, imagem 2 %32
    • Remove the back cover by inserting a fingernail or opening pick here and disengaging the plastic clips.
    • Lift battery up here
  2. LG K20 PLUS Midframe Replacement, Midframe: passo 2, imagem 1 %32
    • Remove 11 Philips screws.
  3. LG K20 PLUS Midframe Replacement: passo 3, imagem 1 %32 LG K20 PLUS Midframe Replacement: passo 3, imagem 2 %32
    • Use fingernails or insert an opening pick into the gap between the digitizer and the midframe and pull the midframe outwards to disengage the plastic clips.
    • Carefully disengage the clips on the bottom as the headphone jack goes through the midframe.
    • Once all the clips have been disengaged, move the midframe outwards and downwards to disengage it from the headphone jack.
Conclusão
Patrick
Membro desde: 05/14/14
6.586 Reputação
Autoria de 21 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 2
Duração total: 73
