O que você precisa
Vídeo de Apresentação
Insert a plastic opening tool under the edge of the rear camera's press-fit connector. Lift the connector up and away from the motherboard to pop the ribbon cable free.
Remove the rear facing camera.
Buen día, muchas gracias por este tutorial. Está bastante claro y me ha resultado útil. Una pregunta, ¿has intentando abrir la cámara? Te comento, deseo remover el filtro de infrarrojo que hay en ella. Si lo has hecho y tienes algún tip o sugerencia para abrir la cámara sin dañarla, y lo puedes compartir, yo te lo agradecería. Saludos y buen día.
Good morning! I’m sorry, I wrote the past comment in spanish and I don’t know why. What I was asking is: have you ever opened the camera? I want to remove the infrared filter, i want to convert the LG K10 camera to infrared. But it’s so small that it’s difficult to do and I would like to know if you have any suggestion to do it. Thanks in advance and best regards!
