Ir para o conteúdo principal
LG K10 Rear Camera Replacement
O que você precisa
Vídeo de Apresentação
  1. LG K10 Rear Camera Replacement, Rear Camera: passo 1, imagem 1 %32
    • Power off the device
    • Remove the backing
  2. LG K10 Rear Camera Replacement: passo 2, imagem 1 %32
    • Remove the battery
  3. LG K10 Rear Camera Replacement: passo 3, imagem 1 %32
    • Unscrew every screw of the bottom of the phone and use guitar picks to remove the plastic frame of the phone
  4. LG K10 Rear Camera Replacement: passo 4, imagem 1 %32
    • With a pick lift the side of the phone, in order to remove the backside
    • Repeat this step on all sides of the phone
  5. LG K10 Rear Camera Replacement: passo 5, imagem 1 %32
    • Once the back is completely off, you now have complete access to the rear camera
    • You also now have access to the rear/ front speakers, and motherboard
  6. LG K10 Rear Camera Replacement: passo 6, imagem 1 %32
    • Insert a plastic opening tool under the edge of the rear camera's press-fit connector. Lift the connector up and away from the motherboard to pop the ribbon cable free.
    • Remove the rear facing camera.
Conclusão
Witrigs
Membro desde: 11/24/15
69.881 Reputação
Autoria de 378 guias
Um comentário
Can you upgrade the original camera with say a G5 camera?
Larry Smith - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 7
Duração total: 1,646
