Ir para o conteúdo principal
LG K10 Display Screen Replacement
O que você precisa
Instruções em vídeo
Conclusão
23 outras pessoas executaram este guia.
Witrigs
Membro desde: 11/24/15
69.454 Reputação
Autoria de 378 guias
5 comentários
Eric, thanks for the guide to replacing the LG K10 screen. I was about to commit to doing one, but when I went to buy a part, the first thing I found was the glass cover over the display, which of course is way cheaper than the whole display. Can you comment about changing out just the glass?
TheGear - Responder
Hello,
Thanks for the awsome guide.
Has anyone had overheating problems on this phone after changing the display?
Cheers
André Santos - Responder
Thanks for the guid. I wish I saw this before i had it sent to a company to fix it. If anyone is seeing this. Don't make the same mistake as I did. I bought a case that just had grip. Buy a coverware case. They are super durable. I dropped my phone on phone call and it shattered with the original case. I dropped my phone down a flite of stairs with the coverware case and it survived without any damage.
Samuel White - Responder
I have a problem after installing a new screen. I followed the same steps like the video . The problem is that the digitizer is not working at all. The screen works fine but not the touch function. I have tried 2 different new screens but the prpblem remains. Do I have to glue the lcd connector to the middle frame?
Filippos Vlachos - Responder
Se o celular cair dentro da agua isso funciona?
lg680023 - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 4
Últimos 30 dias: 20
Duração total: 15,643
