Ir para o conteúdo principal
LG K10 Battery Replacement
O que você precisa
Vídeo de Apresentação
  1. LG K10 Battery Replacement, Battery: passo 1, imagem 1 %32
    • Insert thumb or any other thin flat object into the slight indent on the right of the phone.
  2. LG K10 Battery Replacement: passo 2, imagem 1 %32
    • Gently push against to the sides of the phone to open the case.
  3. LG K10 Battery Replacement: passo 3, imagem 1 %32
    • Push against the battery on the bottom, to take off the battery.
  4. LG K10 Battery Replacement: passo 4, imagem 1 %32
    • Align the new battery with the 4 bronze metals on the top left side of the battery and insert the new battery.
  5. LG K10 Battery Replacement: passo 5, imagem 1 %32
    • Push the bottom case in firmly with both hands to secure the case back onto the phone.
Conclusão
4 outras pessoas executaram este guia.
Witrigs
Membro desde: 11/24/15
69.409 Reputação
Autoria de 378 guias
2 comentários
Lg k10 battery is slow charging. What will i do?
pawan kumar lal - Responder
Lg k10 mobile is very good. But its slow charging. It takes more time to charging. What is problem?
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 4
Últimos 30 dias: 11
Duração total: 6,474
