Introdução
If you encounter the following situations you may need to replace the battery:
Your LG K10 has "stopped charging"?
It charges only when you push or wiggle the charge plug in LG K10?
It charges intermittently, or charges VERY slowly?
Your charge cord does not seem to "lock-in"?
The charge cord plug keeps falling out of your LG K10?
O que você precisa
Vídeo de Apresentação
Insert thumb or any other thin flat object into the slight indent on the right of the phone.
4 outras pessoas executaram este guia.
2 comentários
Lg k10 battery is slow charging. What will i do?
Lg k10 mobile is very good. But its slow charging. It takes more time to charging. What is problem?
